Solution for Air Gapped Environment HoloLens2
We require a fully offline solution to render Global 3D map datasets via unity on a HoloLens2. Currently we used Bing Maps SDK however we now require the product to be available offline and we are having trouble finding a solution.
We also have a React Map GL component that uses MapLibre and mbtiles data served locally in a web app. If we were to go down the Cesium Ion route could the solution be dual functionality and serve both of the applications?
Hello Callum_Gracie,
Can you describe your project in a bit more detail? Are you able to connect to a local area network, or would the HoloLens2 be disconnected from all WiFi networks?
Our Cesium ion Self-Hosted platform is a good fit for air-gapped networks or deployment behind corporate firewalls.
-Jeff
