I’m trying to create a terrain tileset using v4.5.2 of the terrain-tiler.exe. Messages emitted by the tiler are not helpful in understanding the problem. The data is 1 meter lidar derived GeoTIFFs for Pennsylvania (275 GB zip files).
Command line:
C:\...\Software\Cesium\Cesium-ion-3D-Tiling-Pipeline-Windows-4.5.2\bin\terrain-tiler.exe --verbose --input-list H:\Tilesets\FileList.txt --height-reference MeanSeaLevel --output H:\Tilesets\PAMAP_LiDAR.terraindb > H:\Tilesets\PAMAP_verbose.txt 2>&1
Sampling of messages (duplicates removed for brevity):
e[0mIdentifying contiguous north-up raster sourcese[0m
e[0mStitching together contiguous north-up raster sourcese[0m
e[35mWarning: Warning 1: Too large for int: nane[0m
e[35mWarning: More than 1000 errors or warnings have been reported. No more will be reported from now.e[0m
e[0m13390 total raster sources.e[0m
e[33m0% complete.e[0m
e[0m(1 of 81) Adding 1.vrt to tileset. (Using 6352 sources: "38001640PAS_dem.tif",
e[35mWarning: Raster contains invalid elevations that exceed max/min height defined on planet.e[0m
Sample dataset gdalinfo:
e[me[32me]9;8;"USERNAME"e\@e]9;8;"COMPUTERNAME"e\ e[92mJ:\PAMAP_LiDAR\NORTH\17002190PAN_deme[90m
e[90m>e[m e]9;12e\gdalinfo.exe 17002190PAN_dem.tif
Driver: GTiff/GeoTIFF
Files: 17002190PAN_dem.tif
17002190PAN_dem.aux
17002190PAN_dem.rrd
17002190PAN_dem.tif.aux.xml
Size is 3125, 3125
Coordinate System is:
PROJCRS["NAD83 / Pennsylvania North",
BASEGEOGCRS["NAD83",
DATUM["North American Datum 1983",
ELLIPSOID["GRS 1980",6378137,298.257222101,
LENGTHUNIT["metre",1]]],
PRIMEM["Greenwich",0,
ANGLEUNIT["degree",0.0174532925199433]],
ID["EPSG",4269]],
CONVERSION["unknown",
METHOD["Lambert Conic Conformal (2SP)",
ID["EPSG",9802]],
PARAMETER["Latitude of false origin",40.1666666666667,
ANGLEUNIT["degree",0.0174532925199433],
ID["EPSG",8821]],
PARAMETER["Longitude of false origin",-77.75,
ID["EPSG",8822]],
PARAMETER["Latitude of 1st standard parallel",41.95,
ID["EPSG",8823]],
PARAMETER["Latitude of 2nd standard parallel",40.8833333333333,
ID["EPSG",8824]],
PARAMETER["Easting at false origin",1968500,
LENGTHUNIT["us_survey_feet",0.304800609601219],
ID["EPSG",8826]],
PARAMETER["Northing at false origin",0,
ID["EPSG",8827]]],
CS[Cartesian,2],
AXIS["easting (X)",east,
ORDER[1],
LENGTHUNIT["us_survey_feet",0.304800609601219]],
AXIS["northing (Y)",north,
ORDER[2],
LENGTHUNIT["us_survey_feet",0.304800609601219]]]
Data axis to CRS axis mapping: 1,2
Origin = (2190000.000000000000000,170000.000000000000000)
Pixel Size = (3.200000000000000,-3.200000000000000)
Metadata:
AREA_OR_POINT=Area
TIFFTAG_RESOLUTIONUNIT=1 (unitless)
TIFFTAG_SOFTWARE=IMAGINE TIFF Support
Copyright 1991 - 1999 by ERDAS, Inc. All Rights Reserved
@(#)$RCSfile: etif.c $ $Revision: 1.10.1.9.1.9.2.11 $ $Date: 2004/09/15 18:42:01EDT $
TIFFTAG_XRESOLUTION=1
TIFFTAG_YRESOLUTION=1
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 2190000.000, 170000.000) ( 76d57' 7.31"W, 40d37'49.60"N)
Lower Left ( 2190000.000, 160000.000) ( 76d57' 8.50"W, 40d36'10.80"N)
Upper Right ( 2200000.000, 170000.000) ( 76d54'57.63"W, 40d37'48.67"N)
Lower Right ( 2200000.000, 160000.000) ( 76d54'58.87"W, 40d36' 9.87"N)
Center ( 2195000.000, 165000.000) ( 76d56' 3.08"W, 40d36'59.74"N)
Band 1 Block=64x64 Type=Float32, ColorInterp=Gray
Min=382.690 Max=812.590
Minimum=382.690, Maximum=812.590, Mean=456.418, StdDev=89.927
Overviews: 1563x1563, 782x782, 391x391, 196x196, 98x98, 49x49, 25x25
Metadata:
LAYER_TYPE=athematic
STATISTICS_COVARIANCES=8086.79774158226
STATISTICS_MAXIMUM=812.59002685547
STATISTICS_MEAN=456.41761162347
STATISTICS_MEDIAN=402.83999633789
STATISTICS_MINIMUM=382.69000244141
STATISTICS_MODE=384.79998779297
STATISTICS_SKIPFACTORX=1
STATISTICS_SKIPFACTORY=1
STATISTICS_STDDEV=89.926624208753
