The 3dtiles show transparnet in VR
In Unreal’s Blank template,the 3dtiles is good.but in Unreal’s Virtual Reality template,the 3dtiles show wrong.
I’m not sure what would cause that. Have you confirmed the starting template is the only difference? You’ll probably have to compare the Project Settings between the two templates to determine what might be the cause of the difference.
