I want to know how to solve the problem that the json data of 3dtiles terrain is tilted after being loaded through url. According to the document, I used the Place origin Here of CesiumGeoreference, but I still can’t correct the perspective to a horizontal perspective. Is there a problem with my data source or is it the wrong operation?
I’m almost certain this is a transformation issue within your pipeline.
If you choose to not host your data on Ion, you will have to fix this manually before running your tiler (or using options your tiler provides (if it does)).
Obj2Tiles for example specifically has the --y-up-to-z-up parameter for this.
But overall the correction would either start at the point of export of wherever you create your model in (Metashape, RealityScan, Pix4D, etc…), or… by post-processing it in DCC (i.e. Blender).
