/home/zphinx/Cesium/node_modules/request/node_modules/tough-cookie/lib/store.js:1
(function (exports, require, module, __filename, __dirname) { /*!
SyntaxError: Unexpected token ILLEGAL
at exports.runInThisContext (vm.js:53:16)
at Module._compile (module.js:373:25)
at Object.Module._extensions..js (module.js:416:10)
at Module.load (module.js:343:32)
at Function.Module._load (module.js:300:12)
at Module.require (module.js:353:17)
at require (internal/module.js:12:17)
at Object.<anonymous> (/home/zphinx/Cesium/node_modules/request/node_modules/tough-cookie/lib/cookie.js:35:13)
at Module._compile (module.js:409:26)
I was having trouble with the BING API and reinstalled Cesium. This time however I ran into a lot of errors when trying to run node server.js. After npm installing many modules I finally reached a deadend with the above error. Any advice?
