guys ,any help !
when i change pawn view ,sometime crash and report same error .
the error in cesium3dtileset.cpp [ update Last View Update Result State(result) ] function.
ps:
my pawn is not base on DynamicPawn . i add a cesiumGeoreference component in it
move pawn use setActorLocation
rotate pawn use setControlRotation
update armlength to control view distance
Hi @tianxiaojie, welcome to the forum.
Can you post your error log?
Also, what version of the plugin are you using?
Hi @agallegos ,thanks to reply.
Both 4.26 and 4.27 version have this error.
this is the crach log
LoginId:26a10cdf4678e397192067973b91a187
EpicAccountId:e3ad57005a224b6588ea5a55de359667
Unhandled Exception: EXCEPTION_ACCESS_VIOLATION 0x00000277729893c0
UE4Editor_CesiumRuntime!async::detail::task_result_holder<Cesium3DTilesSelection::QuadtreeRasterOverlayTileProvider::LoadedQuadtreeImage>::~task_result_holder<Cesium3DTilesSelection::QuadtreeRasterOverlayTileProvider::LoadedQuadtreeImage>()
UE4Editor_CesiumRuntime!async::detail::task_func<async::detail::inline_scheduler_impl,async::detail::continuation_exec_func<async::detail::inline_scheduler_impl,async::task<Cesium3DTilesSelection::QuadtreeRasterOverlayTileProvider::LoadedQuadtreeImage>,async()
UE4Editor_CesiumRuntime!<lambda_8469fa942235018eca11970165d2867a>::operator()()
UE4Editor_CesiumRuntime!Cesium3DTilesSelection::QuadtreeRasterOverlayTileProvider::LoadedQuadtreeImage::~LoadedQuadtreeImage()
UE4Editor_CesiumRuntime!async::detail::ref_count_base<async::detail::when_all_state<std::vector<async::shared_task<Cesium3DTilesSelection::QuadtreeRasterOverlayTileProvider::LoadedQuadtreeImage>,std::allocator<async::shared_task<Cesium3DTilesSelection::Quadt()
UE4Editor_CesiumRuntime!async::fifo_scheduler::run_all_tasks()
UE4Editor_CesiumRuntime!CesiumAsync::Impl::QueuedScheduler::dispatchQueuedContinuations()
UE4Editor_CesiumRuntime!Cesium3DTilesSelection::Tileset::updateView()
UE4Editor_CesiumRuntime!ACesium3DTileset::Tick() [D:\build\++Portal\Sync\LocalBuilds\PluginTemp\HostProject\Plugins\CesiumForUnreal\Source\CesiumRuntime\Private\Cesium3DTileset.cpp:1405]
UE4Editor_Engine
UE4Editor_Engine
UE4Editor_Engine
UE4Editor_Engine
UE4Editor_Core
UE4Editor_Core
UE4Editor_Core
UE4Editor_Engine
UE4Editor_Engine
UE4Editor_Engine
UE4Editor_Engine
UE4Editor_UnrealEd
UE4Editor_UnrealEd
UE4Editor
UE4Editor
UE4Editor
UE4Editor
UE4Editor
UE4Editor
kernel32
ntdll
Hi @tianxiaojie,
I believe we fixed that bug in v1.7.0 of the plugin, which was published to the Epic Marketplace earlier this week.
If youâre using that version and still have this problem, please let me know.
Kevin
Hi @Kevin_Ring ,i gona to check the crash error ,so i update cesium for unreal to 1.7 version .
but i had another problem .
after i update plugin ,i add cesiumGlobeanchor component to my actor and my pawn in scene
when i play my game in editor ,everything is normal , actor position correct ďź pawn view correctăbut after package the game and play , the pawn view is wrongă
i have no idea in this error .
ue4.27 cesium 1.7.
Hi @tianxiaojie,
I see in your screenshot that the âGeoreferenceâ property on your pawnâs CesiumGlobeAnchor component is not set. If you set that to your sceneâs georeference, does that solve the problem? If not, could you possibly share your project files?
-Alex
hi @agallegos , thank you for reply.
i will try .
in this project , i put cesium part that Georeference ăCesium World Terrain ăpawn and any tiles in sublevel and add the sublevel to main level . than sometime (almost 100% ) will crash .
so i put cesium part to main level , till now this error is disapper ( not test a lot ).
Hi @tianxiaojie,
If youâre still having trouble, can you try updating your version of the Cesium plugin? Recent updates might help with this crash.
-Alex
