# Using Cesium npm package with Nuxt 3
**URL:** <https://community.cesium.com/t/using-cesium-npm-package-with-nuxt-3/29593>\
**Category:** CesiumJS\
**Created:** [January 28, 2024, 2:29pm UTC](https://community.cesium.com/t/using-cesium-npm-package-with-nuxt-3/29593 "2024-01-28T14:29:18Z")\
**Showing post:** 3
**Author:** ![Jacques27](https://sea2.discourse-cdn.com/cesium/user_avatar/community.cesium.com/jacques27/32/11887_2.png) [@Jacques27](https://community.cesium.com/u/Jacques27)\
**Post date:** [January 30, 2024, 12:57am UTC](https://community.cesium.com/t/using-cesium-npm-package-with-nuxt-3/29593/3 "2024-01-30T00:57:52Z")
Hi Toby,
I have indeed and it’s a bit tedious to be honest and it was a lot of trial and error at first but I’ve built multiple projects with it already.
One thing you should probably add is a script to initialise the base URL instead of adding it to the nuxt.config.
> export default function setupCesiumBaseUrl() {
> const cesiumBaseUrl = ‘./lib/cesium’;
> window.CESIUM\_BASE\_URL = cesiumBaseUrl;
I’m calling this function right after imports in my app.vue.
I have also added a script that copies the necessary folders from the node\_modules when you build your app (requires packages “del” and “recursive-copy” to be installed:
> import copy from ‘recursive-copy’;
> import { deleteSync } from ‘del’;
> const baseDir = ‘node\_modules/cesium/Build/CesiumUnminified’;
> const targets = [‘Assets/ **/\*', 'ThirdParty/** /_', 'Widgets/\*\*/_’, ‘Workers/\*\*/\*’, ‘Cesium.js’];
> deleteSync(targets.map((src) =\> `.output/public/lib/cesium/${src}`));
> copy(baseDir, ‘.output/public/lib/cesium’, {
> expand: true,
> overwrite: true,
> filter: targets,
In order to get it running in dev mode instead of building it every time, I’ve also added a “lib” folder at the project root which includes the same as what the script above copies. Below is what my folder structure looks like.
 ![image](https://global.discourse-cdn.com/cesium/original/3X/e/3/e3c071fa6032660af2fce40bb1dfb542de568bd5.png)
Note: My latest cesium project is running with nuxt 3.6.5 and I have not tried this with newer versions of nuxt yet.
Sorry for the short answer, not much time currently, hope it helps.
Best,
Jacques
_[View the full topic](https://community.cesium.com/t/using-cesium-npm-package-with-nuxt-3/29593)._
