Water Plugin Dependency
Hello Team Cesium,
Is there a quick way to remove the water plugin dependency?
I am making a cross platform app, and currently working on iOS.
The water plugin is not working on iOS for me and if I disable it, then I must disable Cesium.
Is there any quick way around this?
Thank you,
-Brandon
Hi @VirtuosoCEO,
Unfortunately, I think you would have to modify the plugin itself to remove the dependency! You can find the plugin source code on Github here.
For starters, the CesiumForUnreal.uplugin file mentions the Water plugin, so you’ll want to remove it from there. You’ll also have to modify MI_CesiumThreeOverlaysAndClippingAndWater to remove the water effect from the material. I imagine there are other places you have to change too, but I haven’t looked into them closely.
