My use case for Cesium is to load it locally, ie not from a webserver, but as file://.
This worked fine until 1.109 which makes use of modules, and apparently browsers don’t like modules loaded via file://
any tips or tricks i can use here?
Thanks.
Thanks.
Hi there,
Thanks for reporting this.
Using the file system directly (ie, file://) is not recommended due to security restrictions some browsers have in place.
However the core issue has been reported previously and we’re tracking it in GitHub. We’re currently taking a look. In the meantime, you can try using a method other than the CDN to import CesiumJS in your application.
Gabby
