3d models not at the right location. Program to edit glft files?
I have some 3d models that are not at the location where they should be. I suspect that the origin is off. Anyone else having issues with this? Is there a program to edit glft files to verify this? These models are converted from kzml and are showing up correctly in the google earth plugin. I have verified that the lat/long cords are correct.
Thanks in advance and let me know if you need more information.
Hi Brian,
I don’t think there is a tool for exactly what you want, but all the glTF tools are listed here:
https://github.com/KhronosGroup/glTF#gltf-tools
When I’ve seen something like this, it is usually due to a large translation in a node’s matrix. Perhaps convert to .glTF and inspect the JSON by hand, and/or trim down the original COLLADA file to simplify debugging.
Patrick
