Hi Team,
I’m implementing a feature as Walk-Through where i’m drawing a line and putting an object to walk through the line. It’s working fine if i’m drawing path from the less height but if i’m drawing the line from the more heights object is not following the path means it’s misplaced from the path. A view is given bellow on the attached screen shots.
Please provide any solution to solve the problem
Thanks
