The geojson temperature properties are organized by time.
I applied color to the polygon material according to the temperature properties of the geojson file.
var promise = Cesium.GeoJsonDataSource.load(’…/geojson/littleGeojson2.geojson’);
console.log(promise);
var entities;
promise.then(function(dataSource){
viewer.dataSources.add(promise);
viewer.zoomTo(promise);
entities = dataSource.entities.values;
changeHeightStyle();
function changeHeightStyle(){
var entity;
var extrudedHeight;
for(var i=0; i<entities.length;i++){
entity = entities[i];
entity.polygon.outline = false;
extrudedHeight = entity.properties.GRO_FLO_CO*5 ;
entity.polygon.extrudedHeight = extrudedHeight;
entity.polygon.material = getColorHeight(extrudedHeight);
colorlegend1.style.display = “block”;
colorlegend2.style.display = “none”;
function getColorHeight(height) {
return height >= 50 ? Cesium.Color.fromCssColorString(’#b2182b’) :
height >= 40 ? Cesium.Color.fromCssColorString(’#ef8a62’) :
height >= 30 ? Cesium.Color.fromCssColorString(’#fddbc7’) :
height >= 20 ? Cesium.Color.fromCssColorString(’#d1e5f0’) :
height >= 10 ? Cesium.Color.fromCssColorString(’#67a9cf’) : Cesium.Color.fromCssColorString(’#2166ac’);
Furthermore, I want to apply temperature properties to the polygon synchronized with the timeline.
I’m not sure how to use timeInterval.
Here is the current code:
function init() {
terrainProvider : ,
selectionIndicator : false //Disable selection indicator
viewer.terrainProvider = new Cesium.CesiumTerrainProvider({
url : ‘//assets.agi.com/stk-terrain/world’
var start = Cesium.JulianDate.fromDate(new Date(2016,0,1,14));
var stop = Cesium.JulianDate.fromDate(new Date(2017,0,11,14));
viewer.clock.currentTime = start;
viewer.clock.startTime = start;
viewer.clock.stopTime = stop;
viewer.clock.multiplier = 1000000;
viewer.clock.clockRange = Cesium.ClockRange.LOOP_STOP;
viewer.timeline.updateFromClock();
viewer.timeline.zoomTo(start,stop);
viewer.clock.onTick.addEventListener(function (clock) {
checkIcon(Cesium.JulianDate.toIso8601(clock.currentTime).substr(0,7));
function checkIcon(iYear) { //년월표시함수
document.getElementById(“years”).style.display = “”;
document.getElementById(“years”).innerHTML = iYear;
new Cesium.ColorMaterialProperty()
return height >= 90 ? Cesium.Color.fromCssColorString(’#b2182b’) :
height >= 80 ? Cesium.Color.fromCssColorString(’#ef8a62’) :
height >= 60 ? Cesium.Color.fromCssColorString(’#fddbc7’) :
height >= 40 ? Cesium.Color.fromCssColorString(’#d1e5f0’) :
height >= 20 ? Cesium.Color.fromCssColorString(’#67a9cf’) : Cesium.Color.fromCssColorString(’#2166ac’);
console.log(typeof getColorHeight(44));
// Load regions
var promise = Cesium.GeoJsonDataSource.load("…/geojson/littleGeojson2.geojson");
var entities;
var values = [
[‘2016-01-01T00:00:00.00Z/2016-02-01T00:00:00.00Z’, Math.random()*100],
[‘2016-02-01T00:00:00.00Z/2016-03-01T00:00:00.00Z’, Math.random()*100],
[‘2016-03-01T00:00:00.00Z/2016-04-01T00:00:00.00Z’, Math.random()*100],
[‘2016-04-01T00:00:00.00Z/2016-05-01T00:00:00.00Z’, Math.random()*100],
[‘2016-05-01T00:00:00.00Z/2016-06-01T00:00:00.00Z’, Math.random()*100],
[‘2016-06-01T00:00:00.00Z/2016-07-01T00:00:00.00Z’, Math.random()*100],
[‘2016-07-01T00:00:00.00Z/2016-08-01T00:00:00.00Z’, Math.random()*100],
[‘2016-08-01T00:00:00.00Z/2016-09-01T00:00:00.00Z’, Math.random()*100],
[‘2016-09-01T00:00:00.00Z/2016-10-01T00:00:00.00Z’, Math.random()*100],
[‘2016-10-01T00:00:00.00Z/2016-11-01T00:00:00.00Z’, Math.random()*100],
[‘2016-11-01T00:00:00.00Z/2016-12-01T00:00:00.00Z’, Math.random()*100],
[‘2016-12-01T00:00:00.00Z/2017-01-01T00:00:00.00Z’, Math.random()*100]
console.log('values : ’ +values);
var colourProperty = new Cesium.TimeIntervalCollectionProperty();
values.forEach(function(entry){
//console.log(‘5’);
colourProperty.intervals.addInterval(Cesium.TimeInterval.fromIso8601({
iso8601 : entry[0],
isStartIncluded : true,
isStopIncluded : false,
data : getColorHeight(entry[1])
console.log(colourProperty);
dataSource.entities.values.forEach(function(entity){
entity.polygon.extrudedHeight = entity.properties.GRO_FLO_CO*10;
entity.polygon.material = new Cesium.Property(colourProperty); // it has problem…T.T
entity.polygon.outlineColor = colourProperty;// it’s OK
window.onload = init;
My ultimate goal is to express the properties of the geojson data (time and temperature of the entities at that time) in time series to change color according to temperature
