If I have czml data loaded via CzmlDataSource with several pieces of data:
"id":"LINE 1",
"name":"LINE 1",
"polyline": {
"width":3,
"material": {
"solidColor": {
"color": {
"rgba": [255,255,255,255]
"positions": {
"cartographicDegrees": [ lat,long,lat1,long1...]
"id":"LINE 2",
"name":"LINE 2",
"polyline": {
"width":3,
"material": {
"solidColor": {
"color": {
"positions": {
How can I retrieve the lat/long from this data? It's not clear how to access data once it has been processed. I would like to essentially allow the user to draw a shape on the globe, and have the application do analysis on the lats/longs that fall within that shape. (The entire polyline may not be included in the shape.) But I'm having trouble retrieving any info, let alone position data.
I have tried:
var mySource = new Cesium.CzmlDataSource(“MyCzmlDataSourceName”);
function displayData() {
mySource.entities.removeAll();
//the first “entity” is selected, but not displayed,
//and none of the other entities are displayed,
//this is not the expected behavior
mySource.load(‘http://path/to/my/data/myfile.czml’).then(function(){
viewer.selectedEntity = mySource.entities.values[0];
alert(viewer.selectedEntity.label.text); // <--displays “[object Object]”
alert(viewer.selectedEntity.label.text.getValue(JulianDate.fromDate(new Date()))); // <--still nothing, I googled and saw something about
//using getValue, but there isn’t a specific time attached to the data.
