Add a imageryProviderViewModel based on a KML
I'm a little new to Cesium and the mapping domain in general so apologies in advance if I get some of the vernacular wrong.
Add a imageryProviderViewModel to the base layer picker based on a KML.
The function below does accomplish what I want but it's a bit hacky and I don't think it's possible to add this to the baselayer picker without something incredibly hacky so I'm open to other solutions.
async function removeBase(viewer) {
  let countryBorders;
  let countryNames;
  try {
    countryBorders = await CzmlDataSource.load(
      "./assets/data/countryBorders.json",
    countryNames = await CzmlDataSource.load(
      "./assets/data/countryNames-v2.json",
  } catch (e) {
    console.log("Failed to load json");
    return false;
  viewer.dataSources.remove(countryBorders);
  viewer.dataSources.remove(countryNames);
  viewer.scene.imageryLayers.removeAll();
  viewer.scene.globe.baseColor = Color.BLACK;
  viewer.dataSources.add(countryBorders);
  viewer.dataSources.add(countryNames);
  return true;
The application I'm working on will be deployed in low bandwidth environments so having the option to have a base layer that is based on a KML and has no additional data requirements past the first load would be ideal.
Cesium: 1.47.0
OS: Windows 10
Browser: Firefox 62.0.2 (64-bit)
I think if your KML looks good as a base layer then removing the imagery and keeping that should be a fine solution. You can see all the available types of imagery providers here:
https://cesiumjs.org/Cesium/Build/Documentation/ImageryProvider.html
I think it would only be worth implementing a custom imagery provider if you were streaming in KML tiles but it sounds like you only need to load all the data initially.
Typically for low bandwidth/offline environment, the Natural Earth Imagery that ships with Cesium is a good fallback:
