Adding Properties with czml-writer
I want to create a properties tag in my czml output. Something like this:
"properties" :{ "type":"B",
                 "domain":"sp" }
What API / classes do I use to create this? I tried using CustomPorpertiesCeisumWriter, but I don't see how to add a key/value map.
Because each custom property can have a different data type and/or different value specification (constant/sampled/interval/etc.) each custom property is created individually.
It sounds like you’re using the czml-writer project, so you can look at:
https://github.com/AnalyticalGraphicsInc/czml-writer/blob/master/DotNet/CesiumLanguageWriterTests/TestCustomPropertiesCesiumWriter.cs
for code examples creating custom properties of various types.
In general, the API is similar to how the rest of the czml-writer API works (open property, write data, close property).
that is close to what I want. I really want a list of properties without having to define a type. But if I have to define a type that is fine. However, i can't get a list of properties, even with a type.
    "properties" : { "plane":{"string":"777"},
                     "car":{"string":"chevy"}
   is what I will take. but what I am getting is this:
    "properties":{
    "plane":{
      "string":"777"
      "properties":{
         "car":{
        "string":"chevy"
I am using Java. Could the Java libraries not be working? I cannot get a list of properties, no matter what I do. here is the java code:
CustomPropertiesCesiumWriter property = packet.openPropertiesProperty();
CustomPropertyCesiumWriter customProperty = property.openCustomPropertyProperty(“DataType”);
customProperty.writeString(“Ships”);
customProperty = property.openCustomPropertyProperty(“Domain”);
customProperty.writeString(“AIR”);
and the output:
“properties”:{ “DataType”:{ “string”:“Ships”, “Domain”:{“string”:“AIR”}
Make sure that you’re not closing the properties writer after each property. Compare your code with the TestMultipleProperties method:
https://github.com/AnalyticalGraphicsInc/czml-writer/blob/master/DotNet/CesiumLanguageWriterTests/TestCustomPropertiesCesiumWriter.cs#L115
Note that the two custom properties are both opened, written, and closed while the containing properties writer remains open.
I figured it out. I needed to close the properties when done.
customProperty.close();
property.close();
Correct, I didn’t realize you were using the Java version. In C# the using statements dispose each writer automatically at the end of the block.
In Java, you can do a similar thing using try-with-resources syntax:
try (CustomPropertiesCesiumWriter customPropertiesWriter = packet.openPropertiesProperty()) {
try (CustomPropertyCesiumWriter customPropertyWriter = customPropertiesWriter.openCustomPropertyProperty(“DataType”)) {
customPropertyWriter.writeString(“Ships”);
try (CustomPropertyCesiumWriter customPropertyWriter = customPropertiesWriter.openCustomPropertyProperty(“Domain”)) {
customPropertyWriter.writeString(“AIR”);
