I have developed an app which uses Cesium to show flight traces for gliders. I have got it working for one trace and it works really well. I now need to add a second glider trace so that they can be compared. I have czml files which are time coordinated so that they start at zero seconds, and provide the actual start time and time band at run time. The first trace always show perfectly, but the second trace is ignored.
The second czml packet is generating the error “The first CZML packet is required to be the document object.” in the Chrome js console, which, to be frank and being new to cesium, I have no idea what it means. I got the first trace working following the Sandcastle example which shows the hang glider flight trace, and try as I might I am having trouble following the API documentation. Great for individual statements, but it doesn’t help with this issue.
The full error is:
t {name: “RuntimeError”, message: “The first CZML packet is required to be the document object.”, stack: “Error↵ at new t (http://localhost:59484/Scripts…calhost:59484/Scripts/Cesium/Cesium.js:554:11146)”}
message
name
“RuntimeError”
stack
“Error↵ at new t (http://localhost:59484/Scripts/Cesium/Cesium.js:517:29185)↵ at Tt (http://localhost:59484/Scripts/Cesium/Cesium.js:554:8811)↵ at Function.It._processCzml (http://localhost:59484/Scripts/Cesium/Cesium.js:554:12095)↵ at At (http://localhost:59484/Scripts/Cesium/Cesium.js:554:10513)↵ at http://localhost:59484/Scripts/Cesium/Cesium.js:554:10266↵ at i.then (http://localhost:59484/Scripts/Cesium/Cesium.js:516:27615)↵ at e (http://localhost:59484/Scripts/Cesium/Cesium.js:516:27328)↵ at Pt (http://localhost:59484/Scripts/Cesium/Cesium.js:554:10243)↵ at It.load (http://localhost:59484/Scripts/Cesium/Cesium.js:554:11894)↵ at Function.It.load (http://localhost:59484/Scripts/Cesium/Cesium.js:554:11146)”
proto
Error
I am developing in .Net/MVC so rather than showing the view razor code I have copied the following from the js console sources. The traces I have truncated to just the beginning and end portions as they are 25,000 points.
var czml = [{
“id”: “document”,
“name”: “CZML Path”,
“version”: “1.0”,
“clock”: {
“interval”: “2017-01-08T00:49:21Z/2017-01-08T04:43:08Z”,
“currentTime”: “2017-01-08T00:49:21Z”,
“multiplier”: 10
“id”: “path”,
“name”: “718_UC - Copy - Copy.igc”,
“description”: “718_UC - Copy - Copy.igc”,
“availability”: “2017-01-08T00:49:21Z/2017-01-08T04:43:08Z”,
“path”: {
“material”: {
“polylineOutline”: {
“color”: {
“rgba”: [102, 255, 255, 255]
“outlineColor”: {
“rgba”: [0, 0, 0, 255]
“outlineWidth”: 2
“width”: 5,
“leadTime”: 10,
//“trailTime”: 1000,
“resolution”: 5
“position”: {
“epoch”: “2017-01-08T00:49:21Z”,
“cartographicDegrees”: [ 0,169.942566666667,-44.55215,1987,1,169.942233333333,-44.5519666666667,1983,2,169.941883333333,-44.5518,1980,3,169.941516666667,-44.5516333333333,1977,4,169.94115,-44.5514666666667,1973,5,169.940766666667,-44.5513166666667,1969,6,169.940366666667,-44.5511666666667,1964,7,169.939966666667,-44.5510166666667,1957,8,169.93955,-44.5508833333333,1949,9,169.939116666667,-44.5507333333333,…14025,169.984016666667,-44.4529333333333,656,14027,169.98345,-44.4539666666667,659]
viewer.dataSources.add(Cesium.CzmlDataSource.load(czml));
if (true) {
var czmlP2 = [{
“id”: “document2”,
“name”: “CZML Path2”,
“version”: “1.0”,
“clock”: {
“multiplier”: 10
“id”: “path2”,
“path”: {
“material”: {
“color”: {
“rgba”: [255, 120, 0, 255]
“outlineColor”: {
“outlineWidth”: 2
“width”: 5,
“leadTime”: 10,
“resolution”: 5
“position”: {
“cartographicDegrees”: [ 0,169.944783333333,-44.5553333333333,2200,1,169.944233333333,-44.5553166666667,2198,2,169.943666666667,-44.5553,2194,3,169.943116666667,-44.5553,2192,4,169.94255,-44.5552833333333,2189,5,169.941983333333,-44.5552833333333,2188,6,169.941416666667,…-44.4512333333333,781,12832,169.9867,-44.45185,778,12833,169.986633333333,-44.45245,775,12834,169.9866,-44.4530666666667,773,12835,169.986583333333,-44.4537,769]
viewer.dataSources.add(Cesium.CzmlDataSource.load(czmlP2));
position: Cesium.Cartesian3.fromDegrees(169.942566666667,-44.55215),
ellipse: {
semiMinorAxis: 1.0,
semiMajorAxis: 1.0,
material: Cesium.Color.BLUE.withAlpha(0.5)
See 1. above
Cesium 1-36, Windows 10 Chrome
