Remove the showBackground option form your label.
var label = viewer\.entities\.add\(\{
position: Cesium\.Cartesian3\.fromDegrees\(\-116\.33555, 39\.66777, 0\),
label: \{
text: "this is a label",
font: '25pt monospace',
style: Cesium\.LabelStyle\.FILL\_AND\_OUTLINE,
outlineWidth: 2,
verticalOrigin: Cesium\.VerticalOrigin\.BOTTOM,
pixelOffset: new Cesium\.Cartesian2\(0, 0\),
backgroundColor: Cesium\.Color\.BLACK\.withAlpha\(0\.5\),
//showBackground: true,
//translucencyByDistance: new Cesium\.NearFarScalar\(10000, 1\.0, 800000, 0\.0\),
show:true,
On Tuesday, May 1, 2018 at 11:23:24 PM UTC-4, think.h...@gmail.com wrote:在 2018年5月2日星期三 UTC+8上午12:39:16,Gabby Getz写道:
> I'm not sure exactly what you mean here, can you create a Sandcastle example to show what the issue is?
> Thanks,
> Gabby
> On Saturday, April 28, 2018 at 3:09:03 AM UTC-4, think.h...@gmail.com wrote:1. A concise explanation of the problem you're experiencing.
> After adding the transparent background color to label, the bottom map is displayed, and the middle entity can not be seen. How can I solve it?
> 2. A minimal code example. If you've found a bug, this helps us reproduce and repair it.
> 3. Context. Why do you need to do this? We might know a better way to accomplish your goal.
> 4. The Cesium version you're using, your operating system and browser.
var ellipse = viewer\.entities\.add\(\{
position: Cesium\.Cartesian3\.fromDegrees\(\-116\.3333, 39\.66666, 0\),
ellipse: \{
semiMinorAxis: 200000,
semiMajorAxis: 200000,
height: 0,
material: Cesium\.Color\.RED,
label: \{
outlineWidth: 2,
show:true,
The part of the ellipse below label becomes transparent.
thanks for the reply.
Setting the showBackground property of label to false can indeed avoid this problem. But my original intention was to give the label a background color. Is there any other way?
I found another problem. When dragging and controlling the map, part of that label is hidden by the underlying ellipse.Is this a bug?
