I am trying to exaggerate the terrain if the area falls within the pre-defined red rectangle area.
However, with the current code below, Im getting the entire globe exaggerated.
Can anyone advise?
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<!-- Include the CesiumJS JavaScript and CSS files -->
<script src="https://cesium.com/downloads/cesiumjs/releases/1.119/Build/Cesium/Cesium.js"></script>
<script src="https://cdn.jsdelivr.net/npm/@turf/turf@6.3.0/turf.min.js"></script>
<link href="https://cesium.com/downloads/cesiumjs/releases/1.119/Build/Cesium/Widgets/widgets.css" rel="stylesheet">
</head>
<body>
<div id="cesiumContainer" style="width: 100%; height: 100vh;"></div>
<div id="toolbar" style="position: absolute; top: 10px; left: 10px; z-index: 100;">
Vertical Exaggeration: <input type="range" min="0" max="10" step="0.1" value="1" id="exaggerationRange">
<span id="exaggerationValue"></span>
</div>
<script type="module">
Cesium.Ion.defaultAccessToken = 'eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJqdGkiOiI4MjViMDdiOC02OTBlLTQyYjgtOTcyYy02YTYzNjczNDgxN2QiLCJpZCI6MjI2NDQ1LCJpYXQiOjE3MjAxMDMzNjV9.tSVOLKfyeiR0kn1e0G13O2PA6E8dLU3J6531muHF16g';
const viewer = new Cesium.Viewer('cesiumContainer', {
terrain: Cesium.Terrain.fromWorldTerrain(),
const geoJsonMountainPolygon = {
type: "Feature",
properties: {},
geometry: {
type: "Polygon",
coordinates: [[
[-122.5, 37.6],
[-122.4, 37.6],
[-122.4, 37.7],
[-122.5, 37.7],
[-122.5, 37.6]
function isCameraInsidePolygon(polygonCoordinates, cameraPosition) {
const bbox = {
minLon: Math.min(...polygonCoordinates.map(coord => coord[0])),
maxLon: Math.max(...polygonCoordinates.map(coord => coord[0])),
minLat: Math.min(...polygonCoordinates.map(coord => coord[1])),
maxLat: Math.max(...polygonCoordinates.map(coord => coord[1]))
return (
cameraPosition.longitude >= bbox.minLon &&
cameraPosition.longitude <= bbox.maxLon &&
cameraPosition.latitude >= bbox.minLat &&
cameraPosition.latitude <= bbox.maxLat
// Function to update the vertical exaggeration within the red polygon
function updateExaggeration() {
const exaggerationRange = document.getElementById('exaggerationRange');
const exaggerationValue = Number(exaggerationRange.value);
// Define a point within the red polygon
const pointInPolygon = turf.point([-122.45, 37.65]);
const isInsidePolygon = turf.booleanPointInPolygon(pointInPolygon, geoJsonMountainPolygon);
if (isInsidePolygon) {
viewer.scene.verticalExaggeration = exaggerationValue;
} else {
viewer.scene.verticalExaggeration = 1.0; // Set default exaggeration for outside polygon
// Update the value display
const exaggerationValueDisplay = document.getElementById('exaggerationValue');
exaggerationValueDisplay.innerText = exaggerationValue;
// Bind the input range to update the exaggeration
exaggerationRange.addEventListener('input', updateExaggeration);
const mountainPolygonEntity = viewer.entities.add({
polygon: {
hierarchy: Cesium.Cartesian3.fromDegreesArray([
-122.5, 37.6,
-122.4, 37.6,
-122.4, 37.7,
-122.5, 37.7,
-122.5, 37.6
material: Cesium.Color.RED.withAlpha(0.5),
outline: true,
outlineColor: Cesium.Color.BLACK
// Update the camera position
viewer.camera.flyTo({
destination: Cesium.Cartesian3.fromDegrees(-122.4175, 37.655, 400),
orientation: {
heading: Cesium.Math.toRadians(0.0),
pitch: Cesium.Math.toRadians(-15.0),
</script>
</body>
</html>
I only want the area that falls within the red polygon to be exaggerated when I use the slider. Any areas outside of this should remain as is
