The position callbackProperty works fine. It updates every time the 'positons' variable is changed. Now I'm trying to do the same thing with the material property but when I do Cesium throws an error
Basically I'm trying to connect a "colorPicker" control to a polygon entity so that when I change a color the polygon's material updates automatically.
Did you ever figure out how to get the functionality you described working? I'm trying to do something really similar (I think) where I control at what moment the entity color changes and what color it changes to. I'm having a hard time modifying the full example that Matthew Amato gave in his response to you to fit my purpose. I cannot figure out how to control the CallbackProperty function so that it is not called infinitely. If you were able to wrap your head around this functionality, I would appreciate some help. Thank you.
The CallbackProperty is designed to be called every frame. If you want to control when the color changes, you can just set the material property to a new value. Here’s an example where I change the color every two seconds:
You should be calling the function itself, I beleive:
var Polygon = viewer.entities.add({
name : ‘Red box with black outline’,
polygon : {
hierarchy : {
positions :
new Cesium.CallbackProperty(function () { getCartesians();}, false)},
material : Cesium.Color.ORANGE.withAlpha(0.5),
heightReference : Cesium.HeightReference.CLAMP_TO_GROUND,
But I think we need more context to figure out what;s going on. Can you create a Sandcastle example showing the problem?
Here, Basic Aim is :
A Polygon should move simultanesously with the Aircraft but at ground level. So i am using callback property coz i may get continuous position of aircraft and i will pass that same positions to polygon.
thereforth, using getCartesians() method in callbackproperty API which I had defined the
getCartesians() method.
technically,
getCartesians()
method will give me cartesian position of aircraft
continuously and i may pass it to draw the polygon
