An error has occurred by process() loading CZML file
i want to load CZML file without clear THE data,which last time has loaded.
so i used the function process() by midifying the demo https://cesiumjs.org/Cesium/Build/Apps/Sandcastle/?src=CZML.html&label=DataSources
like this:
var czmldatasource = new Cesium.CzmlDataSource();
viewer.camera.flyHome(0);
viewer.dataSources.add(czmldatasource.process(’…/…/SampleData/Vehicle.czml’));
viewer.dataSources.add(czmldatasource.process(’…/…/SampleData/simple.czml’));
viewer.scene.camera.setView({
destination: Cesium.Cartesian3.fromDegrees(-116.52, 35.02, 95000),
orientation: {
heading: 6
but, an error has occurred:
undefined
DeveloperError: This object was destroyed, i.e., destroy() was called.
Error
at new DeveloperError (http://localhost:8080/Source/Core/DeveloperError.js:43:19)
at VertexArray.throwOnDestroyed (http://localhost:8080/Source/Core/destroyObject.js:45:19)
at continueDraw (http://localhost:8080/Source/Renderer/Context.js:918:12)
at Context.draw (http://localhost:8080/Source/Renderer/Context.js:957:9)
at DrawCommand.execute (http://localhost:8080/Source/Renderer/DrawCommand.js:502:17)
at executeCommand (http://localhost:8080/Source/Scene/Scene.js:1651:21)
at executeTranslucentCommandsSortedMultipass (http://localhost:8080/Source/Scene/OIT.js:558:13)
at OIT.executeCommands (http://localhost:8080/Source/Scene/OIT.js:600:9)
at scene._executeOITFunction (http://localhost:8080/Source/Scene/Scene.js:1848:32)
at executeCommands (http://localhost:8080/Source/Scene/Scene.js:1961:13)
i want to keep the loaded data last time when i load new czml file.
cesium 1.42. windows7, chrome
Thanks!
Hi there,
If you create a new CzmlDataSource object for each time you want to load new data, a new collection of entities will be created, leaving the old ones. So if you comment out the removeAll line in the original example, it keeps the previous dataSource after loading in the new one. (see modified example)
Gabby
it works well.Thanks
在 2018年2月20日星期二 UTC+8上午4:41:00,Gabby Getz写道:
