I trying to get a angular-cesium demo app working with Angular 5. Seems angular-cesium npm lib (v0.0.36) uses ‘ngOutletContext’ which as been depreciated in Angular 5 and replaced with ‘ngTemplateOutletContext’.
Here is the error I receive when attempting to build the app…
If ‘ngOutletContext’ is an Angular directive, then add ‘CommonModule’ to the ‘@NgModule.imports’ of this component.
To allow any property add ‘NO_ERRORS_SCHEMA’ to the ‘@NgModule.schemas’ of this component. (“ntityId”>
")<ng-template [ngTemplateOutlet]="acHtmlTemplate" [ERROR ->][ngOutletContext]="acHtmlContext"></ng-template> </div>
Error at /Users/billsimac/tpdev/talon-point/tp2-app/node_modules/angular-cesium/src/angular-cesium/components/ac-html-desc/ac-html-desc.component.d.ts.AcHtmlDescComponent.html(4,15): Property binding ngOutletContext not used by any directive on an embedded template. Make sure that the property name is spelled correctly and all directives are listed in the “@NgModule.declarations”. (" id; let acHtmlContext = context">
<div [acHtmlContainer]="acHtmlEntityId">
[ERROR ->]<ng-template [ngTemplateOutlet]="acHtmlTemplate"
[ngOutletContext]="acHtml")
part of my ‘app.module.ts’.
import { AngularCesiumModule } from ‘angular-cesium’;
@NgModule({
declarations: [
AppComponent,
imports: [
BrowserModule,
HttpClientModule,
SharedModule,
CoreModule,
AngularCesiumModule.forRoot(),
I’m not sure if this is the only issue angular-cesium has with Angular 5 but if so, it appears it should be a quick fix. I’ve had to make the change in my own code base (ngOutletContext -> ngTemplateOutletContext) and it worked well.
Hoping to see an update to the angular-cesium lib very soon!!!
“angular-cesium”: “0.0.36”
