Hi, I was wondering if there was any possible ways to make the imagery layers load faster. I have cleared my data, run only one tab on the current version of Google Chrome, and have no extensions running. Is there some flags that i should enable/disable/set?
Hi there,
The biggest factor in imagery load time is your imagery server itself. Can we have some more details on what your server configuration is like?
- Rachel
If you only want to show the imagery layer for a limited area you can provide a rectangle and a minlevel to the cesium ImageryLayer see https://cesiumjs.org/Cesium/Build/Documentation/ImageryLayer.html
If you choose the correct minimum Level cesiumjs does not have to load the complete image pyramid.
Ok, it just seems like geo-fs.com will load some imagery to the highest resolution on one tile, but the next tile will not be loaded to the highest resolution
