Anyone Built a Google Earth-Style Location Search in Unreal with Cesium (C++ or Blueprint)?
Hey everyone! :waving_hand:
I’m currently building a Google Earth-like system using Unreal Engine 5 + Cesium for Unreal, and I’ve already got the 3D globe rendering successfully using Cesium ion and the Google Maps API for terrain/imagery.
The next big feature I want to implement is a Search Bar, just like in Google Earth.
:globe_showing_europe_africa: Feature Description:
The idea is:
  • User types a location name (like “New York” or “Mount Everest”)
  • The system uses Google Maps API (Geocoding) to get the coordinates
  • Then the globe rotates, tilts, and zooms smoothly to that location
  • Optionally, show a marker/pin and a small popup with location name/info
:laptop: Implementation Goal:
  • I want to build this entirely in C++ (though if you’ve done it in Blueprints, I’d love to see that too!)
  • I’d like to create a custom search widget (UUserWidget or Slate), connect it to a C++ class that handles:
    • Calling the API
    • Parsing the coordinates (lat/lon)
    • Using CesiumGeoreference and CesiumGlobeAnchor to move the camera or player pawn to the desired place
:red_question_mark:What I’m Looking For:
  • Has anyone here built this kind of feature already?
  • Any code snippets, logic flow, or example projects would be super helpful!
  • How did you handle the rotation/zoom of the camera in 3D smoothly?
I’m still new to Cesium & Unreal Engine C++ so even basic guidance is appreciated :folded_hands:
Thanks in advance! :light_bulb:
@Piyush_Verma Great question! First off, the geocoding: If you’re using Cesium ion, you can do this through this PR in Cesium for Unreal, which adds a blueprint node for accessing the Cesium ion Geocoder, which interfaces with the Google and Bing geocoders. Take a look at this guide to see how you can use plugin builds from pull requests in Unreal.
To zoom the globe to that location, you’ll want to make the player a Globe Aware Default Pawn. Once you do that, you can call the FlyToLocationLongitudeLatitudeHeight method from Blueprint.
Finally, to show a marker or pin at that location, that’s the job of the Material Billboard Component. Combine that with a Globe Anchor and you should be in business!
Good luck!
