I have a basic question. I know how to change the scene in the viewer through code, but I'd like only the 3D/2D options to be available for the Scene Selection drop-down in the viewer. How can I remove Columbus View from the scene mode picker?
Looks like there’s no API exposed to control this. I opened a feature request with some details on how you might go about changing this:
Looks like Ed Mackey figured out a clever way to hide it with just CSS! See the HTML/CSS tab in his example here: https://github.com/AnalyticalGraphicsInc/cesium/issues/8005#issuecomment-511925272
Perfect. Thank you for digging that up for me Omar!
So far at least, just adding :
.cesium-sceneModePicker-dropDown-icon[data-bind*="COLUMBUS_VIEW"] {
display: none;
to my CSS file does not remove the icon for me. I dont use the bucket.css that Ed used though, and removing that from his sandcastle example breaks it. So I'll have to poke around a bit. At least it looks like it is possible this way!
Only because I want to post a solution here: Omar provided this on github which worked for me :
Adding this in Javascript, using CSS, was able to remove Columbus View
document.querySelector("#cesiumContainer > div > div.cesium-viewer-toolbar > span.cesium-sceneModePicker-wrapper.cesium-toolbar-button > button:nth-child(4)").style.display = 'none';
It worked perfectly! Thanks Omar and John for your help.
Here is a more robust way to remove Columbus View from scene selection if Omar’s solution doesn’t work for anyone.
const buttons = document.querySelectorAll(
'button.cesium-button.cesium-toolbar-button.cesium-sceneModePicker-dropDown-icon',
buttons.forEach((button) => {
if (button.getAttribute('title') === 'Columbus View') {
(button as HTMLElement).style.display = 'none';
