hi all
i am attempting to write out a b3dm for 3D tileset.
i read the various specs
https://github.com/AnalyticalGraphicsInc/3d-tiles/blob/master/TileFormats/Batched3DModel/README.md
https://github.com/KhronosGroup/glTF/tree/master/extensions/Khronos/KHR_binary_glTF
steps i used
1 . i started by creating a binary gltf using the colladaToBglTFConverter tool.
i wrote the 20 byte header for the b3dm ( 0 for the batch table)
then appended the file created from #1.
my files looks nothing like the sample b3dm from the tileset directory
Q1, what exactly is meant by the statement
Binary glTF immediately follows the batch table.
does it mean the entire binary gitf file including header or without the header follows the batch table?
Q2. ar the Binary gITF output from colladaToBglTFConverter tool compatible with cesium…my are generating runtime errors.
Q3. more broadly how are others generating the batched 3d models?
any help appreciated.
-lp
these are the difference between the sample b3dm files and the once i created.
this is the supplied sample that works in sandcastle.
Notice the header.
this generated according to the specs. Notice the magic number of ‘b3dm’ in header.
am i reading the wrong spec or what else have i missed?
thanks
-lp
Hi Lucio,
steps i used
2. i wrote the 20 byte header for the b3dm ( 0 for the batch table)
3. then appended the file created from #1.
yes that is the correct approach - your test.b3dm hexdump looks correct
as well.
The sample differs because is is gzipped and then served over
nodejs with the appropriate "Content-encoding" flag added (i.e.,
it is not compressed on the fly). So you should either gzip the b3dm
before serving, or edit server.js to not add the "Content- Encoding:
gzip" header for b3dm-files.
Try gunzipping the sample if you want to analyze it.
cheers,
Manuel
Hi Lucio,
yes, you should append the entire file including header.
compatible with cesium....my are generating runtime errors.
what errors are you seeing?
Manuel
hello Manual
you have been very helpful, Once i gunzip the sample b3dm files the look similar
it seems the gzip of b3dm has caught me again.
just to confirm.
1.the sample b3dm files are already gzipped on disk.
2.the node.js has content encoding of 'gzip for .b3dm files.
3.when i removed the content encoding of ‘gzip’ from the server.js the sample tileset were NOT displayed.
Q1. so are the files on disk are gzip and then gzip again over the http transfer?
thanks
-lucio
hi all
now i have gzipped my b3dm file i getting a proper error now
Cesium.js:67089 [Cesium WebGL] Vertex shader compile log: ERROR: 0:25: ‘a_batchId’ : undeclared identifier
createAndLinkProgram @ Cesium.js:67089
Cesium.js:67095 [Cesium WebGL] Vertex shader translation failed.createAndLinkProgram @ Cesium.js:67095
Cesium.js:176141 An error occurred while rendering. Rendering has stopped.
undefined
RuntimeError: Vertex shader failed to compile. Compile log: ERROR: 0:25: ‘a_batchId’ : undeclared identifier
Error
at new RuntimeError (http://localhost:8080/Cesium/Cesium.js:9279:19)
at createAndLinkProgram (http://localhost:8080/Cesium/Cesium.js:67100:23)
at initialize (http://localhost:8080/Cesium/Cesium.js:67305:23)
at ShaderProgram.defineProperties.vertexAttributes.get (http://localhost:8080/Cesium/Cesium.js:66967:17)
at getAttributeLocations (http://localhost:8080/Cesium/Cesium.js:109097:93)
at createVertexArrays (http://localhost:8080/Cesium/Cesium.js:109324:46)
at createResources (http://localhost:8080/Cesium/Cesium.js:110169:13)
at Model.update (http://localhost:8080/Cesium/Cesium.js:110584:13)
at Batched3DModel3DTileContent.update (http://localhost:8080/Cesium/Cesium.js:134124:21)
at Cesium3DTile.process (http://localhost:8080/Cesium/Cesium.js:142844:23)CesiumWidget.showErrorPanelCesiumWidget.showErrorPanel) @ Cesium.js:176141
Hi Lucio,
Hi Patick,
I think the issue here is that you need to set the b3dm headers'
"batchLength" to zero if you don't declare the "a_batchId" attribute
in your glb mesh.
> Let me know if you think there is an issue in Cesium here. Anything you
> can do to narrow it down is appreciated.
I'd say cesium is working as expected in this case, although the
documentation for "batchLength" could maybe be made more explicit
about requiring the "a_batchId" attribute if batchLength is non-zero.
Manuel
hi manual and patrick
i see my problem, i didnt have the batchid set in glb as i assumed i didnt need it as i only had a single item in batch.
so from the spec i have to add the following :
- add the batchid to the technique attribute and parameters
ie
from
techniques":{“technique0”:{“attributes”:{“a_normal”:“normal”,“a_position”:“position”},
“parameters”:{“ambient”:{“type”:35666},“diffuse”…
to
techniques":{“technique0”:{“attributes”:{“a_batchId”:“batchId”,“a_normal”:“normal”,“a_position”:“position”},
“parameters”:{“ambient”:{“type”:35666},“batchId”:{“semantic”:“BATCHID”,“type”:5126},“diffuse”…
- add the declaration to the shader
attribute float a_batchId;
does that look correct?
thanks
-lucio
Hi Lucio,
If you do not need the picking functionality, you can do without the
a_batchId attribute by setting batchLength to zero (i.e.,
both batchTableLength + batchLength should be zero in the b3dm header).
cheers,
Manuel
hi manuel
ok i misunderstood the batchlength value.
so i set both batchlength and batchtable to 0
the b3dm now loads without error but nothing is displayed.
all that my scene contains is a red box.
i got nothing left to try out
any suggestions/advice or help is appreciated.
-lucio
I update the b3dm spec to clarify when a_batchId is required, see #78.
Lucio - perhaps compare your file with the sample data used in the unit tests, see
https://github.com/AnalyticalGraphicsInc/cesium/tree/3d-tiles/Specs/Data/Cesium3DTiles/Batched
Patrick
Hi Lucio,
What coordinate system is your mesh expressed in?
Are you using the CESIUM_RTC extension to define a relative
origin?
cheers,
Manuel
hi manuel
i am NOT the CESIUM_RTC extension.
i guess my model is using the UCS of the modelling tool.
i am starting to feel i dont understand very much about 3d data.
Hi Lucio,
you will need to specify the model in ECEF (Earth-Centered Earth-Fixed) cartesian coordinates, with the additional twist that Model.js
transforms from y-Up to z-Up:
https://github.com/AnalyticalGraphicsInc/cesium/blob/3d-tiles/Source
/Scene/Model.js#L132
so you will have to rotate the ECEF coordinates by the inverse transform (i.e., rotate -90° around the x-axis). I am unfamiliar with
collada2gltf, but it might already take care of that step?
To transform from lat/lon/height to cartesian using e.g. GDAL/proj4:
cs2cs +proj=latlon +ellps=WGS84 +datum=WGS84 +to +proj=geocent +ellps=WGS84 +datum=WGS84
cheers,
Manuel
hi manuel
i got no progress with the ECEF coordinates in the model, so i changed direction and looked at using the CESIUM_RTC extension.
https://github.com/KhronosGroup/glTF/tree/master/extensions/Vendor/CESIUM_RTC
i added the following to my model
“extensions” : {
“CESIUM_RTC” : {
“center” : [1215019.3092979142, -4736312.191468832, 4081596.540251589]
“extensionsUsed” : [“CESIUM_RTC”]
and now i am getting a bounding volume drawn in my tileset (without batchtable)…but NOT the actual model!
i assume that my model is now using a coordinate based at value defined in CESIUM_RTC. is that correct?
in the collada model my mesh is defined simply
<float_array id=“Geometry-mesh002-positions-array” count=“24”>-50 -50 -50 -50 50 -50 50 50 -50 50 -50 -50 -50 -50 50 -50 50 50 50 50 50 50 50 50</float_array>
i am thoroughly confused as to why the tileset is not drawn.
Hi Lucio,
reading trough this thread was like reading a journey of my last three days. I had to figure this all out, while the answers were all here…
Did you have any luck with using the CESIUM_RTC extension?
You may have to add this to your b3dm as well:
"techniques": {
"technique0": {
"parameters": {
"modelViewMatrix": {
"semantic": "CESIUM_RTC_MODELVIEW",
"type": 35676
I will implement the extension tomorrow, and hope that the model will appear.
Also if a cesium dev is reading this:
In the b3dm Readme.md the link to CESIUM_RTC Readme.md extension is 404.
In the CESIUM_RTC Readme.md the link to the cesium implementation is 404.
Hello Benjamin
adding the CESIUM_RTC_MODELVIEW to the model worked!
the 3d tile is now visible!
i thought i had already tried that before but who knows.
thanks for you help.
I’m glad I could help!
When I use the CESIUM_RTC extension, the orientation of my model messed up. Is your orientation correct?
