Blending colours
I am trying to blend colors, in particular I would like some type of effect as “lighten” in canvas 2d (using webGL blendEquation and blendFunction).
I am running the following example in sandcastle, but changing the appearance doesn’t seem to change the way colors blend.
Am I making some mistake assigning the blendEquation and blendFunction? Or it just doesn’t work the way I think it does?
Thank you!
var appearance = new Cesium.PerInstanceColorAppearance({
flat: true,
renderState: {
blending: {
enabled: true,
equationRgb: Cesium.BlendEquation.MIN,
equationAlpha: Cesium.BlendEquation.MIN,
functionSourceRgb: Cesium.BlendFunction.ONE,
functionSourceAlpha: Cesium.BlendFunction.ONE,
functionDestinationRgb: Cesium.BlendFunction.ZERO,
functionDestinationAlpha: Cesium.BlendFunction.ZERO
var counter = 10;
for (var i = 0; i < counter; i++) {
for (var j = 0; j < counter; j++) {
viewer.scene.primitives.add(
new Cesium.Primitive({
geometryInstances: new Cesium.GeometryInstance({
geometry: new Cesium.RectangleGeometry({
rectangle: Cesium.Rectangle.fromDegrees(-55 +i, -33 +i, -54 + 2i, -32 + 2i)
attributes: {
color: Cesium.ColorGeometryInstanceAttribute.fromColor(new Cesium.Color(i/counter, j/counter, 0.8, 0.99))
appearance: appearance
My final goal is to render a heatmap.
I think it’s because the independent translucency algorithm that Cesium uses needs to override the blend state.
A couple things to try would be to disable OIT with:
orderIndependentTranslucency : false
Or if you are able, set the appearance translucency to false. It is true by default.
flat: true,
translucent: false,
renderState: {
blending: {
enabled: true,
