Hello all, I’m trying to determine if there is a way to know when the browser has finished rendering the all objects, including data sources as well as the base tiles. I’m currently using
this.viewer.dataSourceDisplay.ready && this.viewer.scene.globe.tilesLoaded
However these are not giving the right timing as the browser is still in the process of rendering when both of these return true. I’m not sure if this is possible.
Thanks for any assistance.
