Bug in "Geometry Instances" tutorial
Code in https://cesiumjs.org/tutorials/Geometry-and-Appearances/#geometry-instances has a bug
Here is the fix
var scene = viewer.scene;
var ellipsoidGeometry = new Cesium.EllipsoidGeometry({
vertexFormat : Cesium.PerInstanceColorAppearance.VERTEX_FORMAT,
radii : new Cesium.Cartesian3(300000.0, 200000.0, 150000.0)
var cyanEllipsoidInstance = new Cesium.GeometryInstance({
geometry : ellipsoidGeometry,
modelMatrix : Cesium.Matrix4.multiplyByTranslation(
Cesium.Transforms.eastNorthUpToFixedFrame(Cesium.Cartesian3.fromDegrees(-100.0, 40.0)),
new Cesium.Cartesian3(0.0, 0.0, 150000.0),
new Cesium.Matrix4()
attributes : {
color : Cesium.ColorGeometryInstanceAttribute.fromColor(Cesium.Color.CYAN)
var orangeEllipsoidInstance = new Cesium.GeometryInstance({
new Cesium.Cartesian3(0.0, 0.0, 450000.0),
attributes : {
color : Cesium.ColorGeometryInstanceAttribute.fromColor(Cesium.Color.ORANGE)
scene.primitives.add(new Cesium.Primitive({
geometryInstances : [cyanEllipsoidInstance, orangeEllipsoidInstance],
appearance : new Cesium.PerInstanceColorAppearance({
translucent : false,
closed : true
Trying to figure out how to place instances.
Win 7, latest chrome and cesium
Thanks for reporting the issue and supplying the fix Patrick.h! I've submitted a pull request and should get that fixed soon.
Should be all good now!
