BUG: Perfomance bug in ClippingPolygonCollection
Hi!
ClippingPolygonCollection.computeIntersectionWithBoundingVolume causes a massive performance hit in the default sandcastle. Something is wrong with the implementation there. Tested on Windows, Nvidia RTX 4090, framerate is about 10fps and a solid +120fps without the clip!
Re-produce:
There are some performance issues with clipping polygons. This is already tracked in Improve Clipping Polygon Performance · Issue #12258 · CesiumGS/cesium · GitHub , which contains some additional details about the source. (I don’t see computeIntersectionWithBoundingVolume in the stack trace there, but there are several functions that may be involved here…)
Thanks! Thats great info in the ticket about this… I ended up adding a “dirty flag”-style temporary solution:
ClippingPolygon.prototype.computeRectangle = function (result) {
  // TODO: Make it possible to edit the polygons.
  if (!this._computedRectangle) {
    this._computedRectangle = new Rectangle();
    PolygonGeometry.computeRectangleFromPositions(
      this.positions,
      this.ellipsoid,
      undefined,
      this._computedRectangle,
  const res = defined(result) ? result : new Rectangle();
  Rectangle.clone(this._computedRectangle, res);
  return res;
