[Bug Report] GeoJSON polygon stroke width broken
Changing the stroke width for a geojson data source does not render it any differently. It’s always 1 pixel wide (even though it says the default is 2). Even looking at the sandcastle example here…
…if you change the width to something else, run it, and then switch to the Basic Styling tab, it doesn’t reflect the changed value. I’ve tried 3, 30, 300, 3000. They all render identically.
Similar problem
The post that @kasatik143 has an explanation in the replies about why this is the case. This issue comes up often and we are working on updating the docs to make it more clear.
