**Hi **
**I found some issues about compressed texture. **
One of my b3dm(gltf1.0 layout) have crn textures.
It is not displayed at 1.36.
Problems are related 2 source files :
issue 1. Source/ThirdParty/GltfPipeline/updateVersion.js
issue 2. Source/Scene/Model.js
issue 1: about gltf1.0 to gltf2.0
After 1.36, model.js convert gltf 1.x => 2.0 at runtime.
But some case, it can’t convert perfect(it is not big issue because anyway we have to go gltf 2.0 somday).
and is it not converted well. so I tried fix it and it works for me: (“For compressedImage3DTiles (ex. CRN, KTX, …) blocks” added)
function objectsToArrays(gltf) { at Source/ThirdParty/GltfPipeline/updateVersion.js
ForEach.image(gltf, function(image) {
var extensions = image.extensions;
if (defined(extensions)) {
var binaryGltf = extensions.KHR_binary_glTF;
if (defined(binaryGltf)) {
image.bufferView = globalMapping.bufferViews[binaryGltf.bufferView];
image.mimeType = binaryGltf.mimeType;
delete extensions.KHR_binary_glTF;
if (Object.keys(extensions).length === 0) {
delete image.extensions;
//For compressedImage3DTiles (ex. CRN, KTX, …)
var extras = image.extras;
if(defined(extras)){
var compressedImage3DTiles = extras.compressedImage3DTiles;
for(var compressName in compressedImage3DTiles){
if(compressedImage3DTiles.hasOwnProperty(compressName)){
var compress = compressedImage3DTiles[compressName];
var binaryGltfForCompress = compress.extensions.KHR_binary_glTF;
if(defined(compress.extensions) && defined(binaryGltfForCompress)){
compress.bufferView = globalMapping.bufferViews[binaryGltfForCompress.bufferView];
compress.mimeType = binaryGltfForCompress.mimeType;
if(!defined(image.bufferView)){
image.bufferView = compress.bufferView;
if(!defined(image.mimeType)){ //just use first mimeType
image.mimeType = compress.mimeType;
delete compress.extensions.KHR_binary_glTF;
if (Object.keys(compress.extensions).length === 0) {
delete compress.extensions;
function moveByteStrideToBufferView(gltf) at Source/ThirdParty/GltfPipeline/updateVersion.js
var imageBufferView = image.bufferView;
if (defined(imageBufferView)) {
image.bufferView = bufferViewShiftMap[imageBufferView];
if(defined(image.extras)){
var compressedImage3DTiles = image.extras.compressedImage3DTiles;
var oldImageBufferView = compress.bufferView;
if (defined(compress.bufferView)) {
compress.bufferView = bufferViewShiftMap[oldImageBufferView];
issue 2:
it is simple mistake: **in ****Source/Scene/Model.js (**add imageId comments added)
function loadTexturesFromBufferViews(model) {
var loadResources = model._loadResources;
if (loadResources.pendingBufferLoads !== 0) {
return;
while (loadResources.texturesToCreateFromBufferView.length > 0) {
var gltfTexture = loadResources.texturesToCreateFromBufferView.dequeue();
var gltf = model.gltf;
var bufferView = gltf.bufferViews[gltfTexture.bufferView];
var onerror = getFailedLoadFunction(model, ‘image’, 'id: ’ + gltfTexture.id + ', bufferView: ’ + gltfTexture.bufferView);
if (gltfTexture.mimeType === ‘image/ktx’) {
//loadKTX(loadResources.getBuffer(bufferView)).then(imageLoad(model, gltfTexture.id)).otherwise(onerror);
//=> add imageId
loadKTX(loadResources.getBuffer(bufferView)).then(imageLoad(model, gltfTexture.id, gltfTexture.bufferView)).otherwise(onerror);
++model._loadResources.pendingTextureLoads;
} else if (gltfTexture.mimeType === ‘image/crn’) {
//loadCRN(loadResources.getBuffer(bufferView)).then(imageLoad(model, gltfTexture.id)).otherwise(onerror);
//=> add imageId
loadCRN(loadResources.getBuffer(bufferView)).then(imageLoad(model, gltfTexture.id, gltfTexture.bufferView)).otherwise(onerror);
} else {
var onload = getOnImageCreatedFromTypedArray(loadResources, gltfTexture);
loadImageFromTypedArray(loadResources.getBuffer(bufferView), gltfTexture.mimeType)
.then(onload).otherwise(onerror);
++loadResources.pendingBufferViewToImage;
After two patches, I could see it normally.
I just want to it help someone.
thanks, Cesium team
shyoo
