The entity default LMB select selects the wrong entity if the polygon has alpha in it's material.
The bug is that if you have 2 or more polygons above each other with alpha in their material, the select function doesn't select the entity closer to the camera but goes THROUGH and selects the bottom polygon.
In this example I try click the top polygon (BLUE) but it selects the bottom polygon (RED). If you remove the alpha, it correctly select the top blue entity.
1.48
Thanks for reporting this. The fact that they’re translucent means they’re rendered differently, so there’s a different way to pick (see https://cesiumjs.org/Cesium/Build/Documentation/Scene.html#pickTranslucentDepth). However, it looks like that still doesn’t work with Scene.pick. So I think this is a bug or just a missing feature.
No Problem, yeah I tried tampering with the translucent depth boolean and that didn't work. So for now I've just made my own pick function to get around this. I drill pick then pick the entity with the highest height in the array.
