Does Cesium have a method to calculate the area of a polygon. I want to show the area of the irregular polygon in squared meters is it possible. could you please suggest me.
Rama
Rama
Cesium itself currently does not define a method to do this, but checkout geometry or GIS related forum for an algorithm to do so. You can most likely implement the solution using the Cesium API.
Gabby
“IF” it is possible to measure the height of buildings with incesium.
Rama devi
