I use the following code
var windowPosition = new Cesium.Cartesian2(viewer.container.clientWidth / 2, viewer.container.clientHeight / 2);
var pickPosition = viewer.camera.pickEllipsoid(windowPosition);
// var position = Cesium.Cartesian3.fromDegrees(11.35463381710764, 49.063505);
var position = pickPosition;
var positionCBP = function(){
return position;
myTarget = viewer.entities.add({
name : 'Target on surface',
position: new Cesium.CallbackProperty(positionCBP, false),
billboard: {
image: 'Images/target.png',
heightReference: Cesium.HeightReference.NONE
for dynamically picking. there also exists an example as sandcastle Cesium Sandcastle
But in typescript I get errors similar:
TS2322: Type ‘CallbackProperty’ is not assignable to type ‘Cartesian3 | PositionProperty | undefined’.
Type ‘CallbackProperty’ is missing the following properties from type ‘PositionProperty’: referenceFrame, getValueInReferenceFrame
In Various TS issues/questions · Issue #8927 · CesiumGS/cesium · GitHub Matthew talks about this for Cesium 1.71 but I didn’t found it. There is also CallbackProperty and positions · Issue #8944 · CesiumGS/cesium · GitHub concerning this topic.
Is there a solution ?
Rüdiger
