Hi to all,
First of all, congrats to entire Cesium’s team. I’m new on Cesium. It is really great. Powerful 3D visualization in your web browser without installing anything!!!
I’m programming a 3D viewer and I want to perform some flights and animations between different camera positions.
What is the equivalence between
createAnimationCartographic **destination, direction and up **
and
lookat eye, target and up ???
destination <-> eye
direction <-> target
**up <-> up **
I tried with these equivalences but, the result that works OK in lookat, fails (bad camera orientation, 2D positioning ok) in createAnimationCartographic.
Any hints???
Thanks in advance!
The direction is a unit vector in the direction you want the camera to look. Target is the actual position being looked at. The mapping would then be:
destination <-> eye
up <-> up
direction <-> target.subtract(eye).normalize()
Also, since eye and target are cartesians, you can use createAnimation instead of createAnimationCartographic.
Thanks Daniel!
I tried to do that
Target is a Cartesian3. Eye is a Cartesian3.
target.subtract(eye) works well, but when I tried to aply normalize method I obtain this error:
Uncaught TypeError: Object function (e){return i.normalize(this,e)} has no method ‘cross’
Refering to javascript code of Cesium:
Cesium.js:406
I verified that Cesium is correctly installed and setup (following website instructions, webserver is Apache)
Any hint???
Many thanks in advance again!
Can you copy/paste your code? I think you may have forgotten to put parentheses after the call to normalize.
Thanks Scott.
Thanks Daniel.
I have to normalize also the up vector.
Now it works well!
However I detect that the fly is not smooth… I mean: If I am in a position near to the one I want to flight, the path of the flight is not the shortest, also the flight movement includes some rare twists… I don’t know if this is the normal behavior or there is something that I am not doing right…
Thanks again!
