Can anyone this shader explan?
I am making a custome shader.
"czm_material czm_getMaterial(czm_materialInput materialInput)\n" +
"{\n czm_material material = czm_getDefaultMaterial(materialInput);\n" +
"material.diffuse = 1.5 * color.rgb;\n" +
"vec2 st = materialInput.st;\n" +
"float dis = distance(st, vec2(0.5, 0.5));\n" +
"float per = fract(time);\n" +
"if(dis > per * 0.5){\n" +
"discard;\n" +
"}else {\n" +
"material.alpha = color.a * dis / per / 2.0;\n" +
"}\n" +
"return material;\n" +
Can you explain what kind of effect you’re trying to do?
