Can globe be shifted to left or right of center?
Is it possible to shift the globe to the left or right of center?
I would like to display the starfield below a transparent navigation sidebar, and shift-right the globe a distance equal to the width of the sidebar.
Cesium 1.55
I think the easiest way might be to simply scale the canvas itself, assuming your sidebar is an HTML element?
Otherwise, this Camera Sandcastle shows you how to programmatically move the camera, so you can move it to the left/right that way too:
https://cesiumjs.org/Cesium/Build/Apps/Sandcastle/?src=Camera%20Tutorial.html
在 2019年4月6日星期六 UTC+8上午12:40:53,edhi...@gmail.com写道:
The problem I see in any approach like this, is that globe is moved again to the center as soon as an API like flyTo is called.
Seems there’s no way to change the reference system in this case.
