Can I use any fabric material with the Entity API?
I currently trying to create a Polygon using the Fade material from https://cesiumjs.org/Cesium/Build/Documentation/Material.html
However PolygonGraphics (https://cesiumjs.org/Cesium/Build/Documentation/PolygonGraphics.html) defines material as MaterialProperty which can only be one of the following...
  ColorMaterialProperty
  CompositeMaterialProperty
  GridMaterialProperty
  ImageMaterialProperty
  PolylineGlowMaterialProperty
  PolylineOutlineMaterialProperty
  StripeMaterialProperty
Is there anyway to pass a fabric notation material into a entity construct or do I have to create a class similar to ColorMaterialProperty and implement getType() etc. myself?
I’ve managed to get this working… by creating a custom MaterialProperty which allows fabric notation to be passed in… I can’t help but feeling I’m missing something… Surely this must be provided ‘out of the box’…?
var area = Cesium.Cartesian3.fromDegreesArray([-4, 50, 4, 52, 4, 48]);
var CustomMaterialProperty = function (material) {
this._definitionChanged = new Cesium.Event();
this._material = material;
Cesium.defineProperties(CustomMaterialProperty.prototype, {
isConstant: {
get: function () {
return true;
definitionChanged: {
get: function () {
return this._definitionChanged;
CustomMaterialProperty.prototype.getType = function (time) {
return this._material.type;
CustomMaterialProperty.prototype.getValue = function (time, result) {
var key;
for (key in this._material.uniforms) {
result[key] = this._material.uniforms[key];
polygon: {
hierarchy: area,
material: new CustomMaterialProperty({
type: ‘Fade’,
uniforms: {
fadeInColor: new Cesium.Color(1.0, 0.0, 0.0, 0.5),
fadeOutColor: new Cesium.Color(0.0, 0.0, 0.0, 0.0),
maximumDistance: 1,
repeat: false,
fadeDirection: {
x: true,
y: false
time: new Cesium.Cartesian2(0, 0)
outline: true,
outlineWidth: 10
