when you zoom in our out the new map tiles for the new zoom level are loaded with a fade-in effect
if you change the heading/pitch of the camera, and you zoom in, all the map tiles (until the horizon) will be replaced (with fade-in effect) with the right ones to ensure a constant quality of the overall map.
when you zoom in our out the new map tiles for the new zoom level are not loaded with a fade-in effect
if you change the heading/pitch of the camera, and you zoom in, only the nearest tiles will be replaced (without fade-in effect) with the right ones. So often times the overall map will have a quality break very much visible.
In attachment there’s a picture to show better what I mean.
I think alpha blending levels of detail is a really good idea! We’ve been working on something to do that for 3D Tiles, but having it work for imagery as well would be great, so I opened a feature request here: https://github.com/AnalyticalGraphicsInc/cesium/issues/8140
For your other question about a consistent map quality, this is actually a “feature not a bug” in a way. Notice how the Mapbox map cannot tilt beyond a certain angle, because there would be too many tiles in the horizon to load, whereas the CesiumJS map is not limited to this because it can load varying levels of detail across the view.
You can tweak the tolerance for the quality levels of imagery layers by setting viewer.scene.globe.maximumScreenSpaceError. It defaults to 2, but setting it to 1.5 or 1.2 should trigger higher levels of detail without having to zoom in so close. Setting it to 1 will load the highest available level of detail, but isn’t recommended for the issue I described above (if you tilt all the way to the horizon, you don’t want the map to load the hundreds of thousands of tiles it would take).
