I had created a cone with primitive in version 1.42, using below code, but that has stopped working in 1.49
Error:
undefined
DeveloperError: Appearance/Geometry mismatch. The appearance requires vertex shader attribute input 'color', which was not computed as part of the Geometry. Use the appearance's vertexFormat property when constructing the geometry.
Error
at new DeveloperError (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:540:19)
at validateShaderMatching (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:107620:27)
at createShaderProgram (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:108127:9)
at Primitive.update (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:108482:13)
at PrimitiveCollection.update (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:140218:27)
at updateAndRenderPrimitives (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:239403:27)
at executeCommandsInViewport (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:239260:13)
at updateAndExecuteCommands (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:239123:13)
at render (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:239694:9)
at tryAndCatchError (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:239714:13)
var cone = new Cesium.CylinderGeometry({
length: 200,
topRadius: 0.0,
bottomRadius: 50,
vertexFormat: Cesium.PerInstanceColorAppearance.VERTEX_FORMAT
//var geometry = Cesium.CylinderGeometry.createGeometry(cone);
var conicalInstance = new Cesium.GeometryInstance({
geometry:cone,
modelMatrix : Cesium.Matrix4.multiplyByTranslation(Cesium.Transforms.eastNorthUpToFixedFrame(
Cesium.Cartesian3.fromDegrees(-75.59777, 40.03883)), new Cesium.Cartesian3(0.0, 0.0, 1000000.0), new Cesium.Matrix4()),
attribute : {
color : Cesium.ColorGeometryInstanceAttribute.fromColor(Cesium.Color.YELLOW.withAlpha(0.6))
var visibility = new Cesium.Primitive({
geometryInstances : conicalInstance,
asynchronous : false,
appearance : new Cesium.PerInstanceColorAppearance({
//flat : true,
translucent : true})
viewer.scene.primitives.add(visibility);
