[cesium-dev] KML support
The nice thing about open source is that we can both pursue different approaches and in the end, the best approach will win. The Cesium project’s development philosophy is that the best answer from a technical perspective wins, it doesn’t matter who wrote the code. I have no problem with you continuing down your path, whether you plan on trying to get it merged into Cesium is up to you. Perhaps we can even end up sharing some code regardless.
Once both approaches have matured, I’m sure we can compare and contrast the benefits and drawbacks of each. Cesium’s goal is to ultimately support the entire KML spec, as well as the Google standard gx extensions. So anything going into master will have to show that an architecture is in place to achieve that goal. We also want to be able to manipulate and browse the KML tree similar to how the Google Earth GUI works. You can see the dataSourceBrowser branch for an early alpha of where we are heading with this.
I’m pretty sure that there is an easy fix for Gabor’s concerns. Can you share a KML file that shows the issue so we can be sure to fix the bug? I’m pretty sure I know exactly what you’re talking about, but I just want to confirm we are on the same page and I figured getting a snippet from you would be the easiest way to do that.
Matthew,
project's development philosophy is that the best answer from a
technical perspective wins, it doesn't matter who wrote the code. I
sure, especially non-rendering code like gx:Tour, which manages the
camera and uses the Timeline widget, etc.
Once both approaches have matured, I'm sure we can compare and
contrast the benefits and drawbacks of each. Cesium's goal is to
I'm pretty sure that there is an easy fix for Gabor's concerns. Can
bug? I'm pretty sure I know exactly what you're talking about, but I
let me paste Gabor's description from earlier. also you can use for
example this file: http://www.diamondaviators.net/reports/files/4427?mode=3d
where is how it renders with our implementation using Geometries:
http://openaviationmap.org/reggeli/
here is Gabor's description of the issue from earlier:
It seems that the way KML styles and objects are merged and eventually transformed to dynamic scene objects has an inherent flaw. I'm still learning the code but to my best understanding all collected styles are mixed together to form a new dynamic object even a particular definition is not applicable to a KML geometry. This leads to geometry misinterpretation.
Given the following KML example
<kml xmlns="http://www.opengis.net/kml/2.2&quot;&gt;
  <Document>
    <Style id="flightpath">
      <LineStyle><color>7f00ffff</color><width>4</width</LineStyle>
      <PolyStyle><color>7f00ff00</color></PolyStyle>
    </Style>
    <Placemark>
      <styleUrl>#flightpath</styleUrl>
      <LineString>
        <coordinates>...</coordinates>
      </LineString>
   </Placemark>..
The renderer ends up calculating overlaps and intersections of a polygon consisting of 1500 vertices instead of drawing a simple set of lines just because of existence of .polygon property derived from PolyStyle definition.
I'm working out a fix that applies only certain dynamic properties to the target objet depending on the geometry type of the original KML placemark. Please confirm that I'm going the right direction.
Dear All,
I completed a prototype to play a gx:Tour animation.
Please find my changes here https://github.com/segabor/cesium/tree/gxtour
Features:
  • can load and play a whole gx:Tour animation sequence
  • optimized route calculation, fly through the entire sequence instead of doing it point by point
  • accelerate animation with optional speed parameter.
  • Sandcastle demo widget “gxTour” added for preview.
Known issues:
  • Rotation is not applied to camera view as it interacts with heading.
  • Animation never reaches the final location.
Future plans:
  • Bugfixes
  • Add animation control panel.
  • Stop / pause animation
I appreciate your feedback.
Gábor
