回复:[cesium-dev] Re: how transport a picture to postProcessStage
do i need bind texture created by webgl to a textureUint? what’ the max number of textureUnit used by cesium?
It’s hard to tell here without seeing your full code. Have you already successfully rendered the scene to a texture? Can you show the code for that?
By the way ,are gl_FragCoord.z and gl_FragCoord.w in postProcessStage the same as raw WebGL ?
It should be, yes.
a lot of errors from consolo,like below
WebGL: INVALID_ENUM: bindTexture: invalid target
[.WebGL-11FFF320]RENDER WARNING: there is no texture bound to the unit 0
and it seems render to srceen when I use ”viewer.scene.render()“ after “gl.bindFramebuffer(gl.FRAMEBUFFER, fbo)”
these are my code ,but it seems not work properly.
//store current camera status
var curCameraPos = viewer.scene.camera.positionWC;
var curCameraDir = viewer.scene.camera.direction;
var curCameraUp = viewer.scene.camera.up;
//camera go to light postion
viewer.scene.camera.position = visibleStartPoint;
viewer.scene.camera.direction = new Cesium.Cartesian3(endPoint.x - visibleStartPoint.x, endPoint.y - visibleStartPoint.y, endPoint.z - visibleStartPoint.z)
//record lightView Matrix;
var lightViewMatrix = viewer.scene.camera.viewMatrix;
// Get the rendering context for WebGL
var gl = viewer.canvas.getContext(“webgl”)
viewer.canvas.getContext(“experimental-webgl”);
var OFFSCREEN_WIDTH = 2048, OFFSCREEN_HEIGHT = 2048;
gl.activeTexture(gl.TEXTURE0);
//create frameBufferObject
var fbo = initFramebufferObject(gl, OFFSCREEN_WIDTH,OFFSCREEN_HEIGHT);
gl.bindFramebuffer(gl.FRAMEBUFFER, fbo); // Change the drawing destination to FBO
gl.viewport(0, 0, OFFSCREEN_HEIGHT, OFFSCREEN_HEIGHT); // Set view port for FBO
gl.clear(gl.COLOR_BUFFER_BIT | gl.DEPTH_BUFFER_BIT); // Clear FBO
//render to fbo
viewer.scene.render();
// Change the drawing destination to color buffer
gl.bindFramebuffer(gl.FRAMEBUFFER, null);
gl.viewport(0, 0, viewer.canvas.width, viewer.canvas.height);
//restore camera postion
viewer.scene.camera.position = curCameraPos;
viewer.scene.camera.direction = curCameraDir;
viewer.scene.render();//
//then I add texture of fbo to postProcessStage
viewer.scene.postProcessStages.add(new Cesium.PostProcessStage({
fragmentShader: FSHADER_SOURCE,
uniforms: {
u_ShadowMap: fbo.texture}
I think you might need to dig around in the source to see some examples of this. I think you need to initialize a Texture object:
https://github.com/AnalyticalGraphicsInc/cesium/blob/master/Source/Renderer/Texture.js
Or possible just use the createUniform function to wrap it:
https://github.com/AnalyticalGraphicsInc/cesium/blob/master/Source/Renderer/createUniform.js
You might also find this series helpful for context in understanding Cesium’s rendering engine and where to look in the source code:
And more blogs on that:
https://cesium.com/blog/categories/webgl/
Is there some example code for rendering to FBO, I am still blocked here
I think Rayman’s blog post here talks a bit about it, and there’s a link to his app’s source code that might be helpful:
https://cesium.com/blog/2019/04/29/gpu-powered-wind/
