We are evaluating cesium for an existing application that works with NASA world wind and were able to work through the examples as a standalone application. First attempt is very simplistic and works. Unfortunately when we integrate with our application the widgets.css does not seem to load. The file does not get downloaded
on the client side, all other assets load.
Indext.html
<script src="resources/cesium/Cesium.js"></script>
<link href="resources/cesium/Widgets/widgets.css" rel="stylesheet">
<link rel="stylesheet" type="text/css" href="resources/LoadMask.css" />
<style>
@import url("resources/cesium/Widgets/widgets.css");
</style>
mapController
myMapWidget.setHtml(’
’);//Cesium
Here
Cesium.Ion.defaultAccessToken = ‘’;
var viewer = new Cesium.Viewer('mapListCanvas', {
geocoder: true,
baseLayerPicker: true,
Simple helloworld working example
NASA world wind is shutting down soon and we need to find an alternate solution. We want to instantiate the map is specific UI element, hence we need to instantiate the Cesium Viewer at a different point.
Cesium 1.56.1,
Sencha 6.2
Wild fly server
Windows 10 and chrome
