We have object picking example but I would like it to be able selecting multiple objects. Is it possible?
You’re in complete control of that logic in your application. Notice that this example clears all previously selected buildings on click. You can change this logic, so comment out line 93:
//silhouetteGreen.selected = ;
And then change line 114 to add onto the array instead of replacing it:
silhouetteGreen.selected.push(pickedFeature);
And that will allow you to select multiple buildings. You can also change the UI to loop over all the selected buildings to display their names/properties instead of just the last selected one. Hope this helps! What kind of application are you working on?
Oh huge thanks OMAR!!!
2019 m. rugpjūtis 6 d., antradienis 19:01:05 UTC+2, Omar Shehata rašė:
