I have been troubled here.At first, it was a problem with incomplete cloning. After I solved it, Visual Studio kept reporting various errors. The cesium native file that I am currently running was copied from someone else, and he can compile it normally, but I still have problems in Visual Studio.
Your screenshots are missing the real errors, but I suspect you’re running into the error that was fixed in this PR:
I don’t know. It probably wouldn’t hurt to try repeating the process again from the beginning. If you’re still having trouble, please document the exact steps you’re following so we can try to reproduce it.
Thank you for your reply. I will repeat this process again. Your comments are very helpful in guiding me in the right direction.
