Hey,
I need to make a ring.
Is it possible? So far I thought I needed to use PolygonHierarchy while having the outer ring with 360 points and inner ring with different set of points.
I've found an older post from 3 years ago, but cesium has changed since then.
(ref: https://groups.google.com/forum/#!topic/cesium-dev/Iu3gH7swmLU)
Would apprentice code or any suggestions you make have.
The final goal is to have something as the following ring:
Thanks for the suggestions.
