Cesium.ScreenSpaceEventHandler gets called many times
Hi -- I have a java script that plots some data points on Cesium.
If I right click on a data point I get a popup alert window that displays information on that data point. When I close the window it closes and then relaunches. It will probably do this over 50 times before it stops.
I modeled my code off of some example code.
The example code does not have this type of behavior.
I'm wondering what is wrong in the Cesium.ScreenSpaceEventHandler code that I am using.
Here is the code for the Cesium.ScreenSpaceEventHandler.
var scene = viewer.scene;
var canvas = viewer.canvas;
var handler = new Cesium.ScreenSpaceEventHandler(canvas);
handler.setInputAction(function(click) {
    console.log("In Handler for click event");
    var alertText = '';
    function addToMessage(key, value) {
  alertText += key + ': ' + value + '\n';
    var pickedObject = scene.pick(click.position);
    console.log(pickedObject);
    console.log(pickedObject.id._id);
    console.log(Cesium.defined(pickedObject));
    console.log(pickedObject.id == entity);
    if (Cesium.defined(pickedObject)) {
        addToMessage(pickedObject.id.description);
        var position = viewer.camera.pickEllipsoid(click.position);
  var cartographicPosition = Cesium.Ellipsoid.WGS84.cartesianToCartographic(position);
  terrainSamplePositions = [cartographicPosition];
  Cesium.sampleTerrain(viewer.terrainProvider, 9,terrainSamplePositions).then(function() {
  }).always(function() {
      alert(pickedObject.id.description);
  handler.destroy();
}, Cesium.ScreenSpaceEventType.RIGHT_CLICK);
I want to be able to show information about the data poits displayed in Cesium.
Cesium Version 1.36
OS Windows 7 Enterprise
Browser Internet Explorer 11
