Cesium SDK terrain tiler
I used terrain tiler 8on premise) to generate a terraindb - in whih way is it possible to generate vertex normals, i.e. for terrain lighting ?
Is there a parameter to do this ?
Rüdiger
Hi Ruiger
Normals are generated automatically for lightning and are done always. If you are using CesiumJS, you may need to enable lighting at runtime. See Cesium Sandcastle as an example.
Shehzan
Hi @Shehzan_Mohammed,
thank you for the infomation, I would like to use the vertex-information at the ShadowMap - so I think the requestVertexNormals should be sufficent.
It is good that the lightning information is generated automatically - maybei my geoserver doesn’t delivers this information.
Regards
Rüdiger
@Shehzan_Mohammed
Everything fine - it works now
the error was in the server
