I am trying to run cesium sensor in cesium-1.17.
I get error “Length” attribute is not defined.
How can it be fixed
How can it be fixed
Great. It works. Thanks
How can we edit a sensor. I created a rectangular sensor and now want to change its radius and x y angles.
I created sensor using this example https://github.com/AnalyticalGraphicsInc/cesium-sensors/tree/master/Examples/api.html
Hello my sample :
<!DOCTYPE html>
<html lang="en">
<head>
<!-- Use correct character set. -->
<meta charset="utf-8">
<!-- Tell IE to use the latest, best version (or Chrome Frame if pre-IE11). -->
<meta http-equiv="X-UA-Compatible" content="IE=Edge,chrome=1">
<!-- Make the application on mobile take up the full browser screen and disable user scaling. -->
<meta name="viewport" content="width=device-width, height=device-height, initial-scale=1, maximum-scale=1, minimum-scale=1, user-scalable=no">
<title>Cesium Sensors simple</title>
<link rel="stylesheet" href="//cesiumjs.org/releases/1.16/Build/Cesium/Widgets/widgets.css" />
<script src="//cesiumjs.org/releases/1.16/Build/Cesium/Cesium.js"></script>
<script src="CesiumSensors.js"></script>
<style>
#cesiumContainer {
position: absolute;
top: 0;
left: 0;
height: 80%;
width: 100%;
margin: 0;
overflow: hidden;
padding: 0;
html {
height: 100%;
body {
padding: 0;
margin: 0;
overflow: hidden;
height: 100%;
background-color: black;
color:white;
font-family: sans-serif;
#toolbar {
position: absolute;
bottom: 0;
left: 0;
height: 20%;
width: 100%;
margin: 0;
overflow:auto;
padding: 0;
#toolbar>div{
margin-left: 30px;
table {
width: 80%;
tbody{
th, td {
padding: 7px;
text-align: left;
>img {
max-width: 30px;
max-height: 30px;
</style>
</head>
<body>
<div id="cesiumContainer"></div>
<div id="toolbar">
<div>
<span>coordonnées de la pointe </span>
<label for="latOrigine">latitude (en °):</label>
<input type="number" value="30" min="-90" max="90" step="0.1" id="latOrigine" name="latOrigine"/>
<label for="longOrigine">longitude (en °):</label>
<input type="number" value="-90" min="-180" max="180" step="0.1" id="longOrigine" name="longOrigine"/>
<label for="hauteurOrigine">hauteur (en m):</label>
<input type="number" value="3000000" min="0" max="10000000" step="100" id="hauteurOrigine" name="hauteurOrigine"/>
<label for="couleurLat" style="margin-left: 30px;">couleur latérale:</label>
<input type="color" value="#FFFFFF" id="couleurLat" name="couleurLat"/>
<label for="couleurInter" style="margin-left: 10px;">couleur intersection:</label>
<input type="color" value="#FFFFFF" id="couleurInter" name="couleurInter"/>
<label for="rayon" style="margin-left: 10px;">rayon (en m):</label>
<input type="number" value="10000000" min="1" max="100000000" step="10" id="rayon" name="rayon"/>
<label for="epaisseur" style="margin-left: 10px;">epaisseur intersection: </label>
<input type="number" value="1" min="1" max="15" step="1" id="epaisseur" name="epaisseur"/>
</div>
<div>
<span>orientation du senseur (référentiel local: 1er axe=>vers le nord, 2ème axe vers l'est, 3ème axe vers le centre de la Terre) </span>
<label for="heading">heading (en °):</label>
<input type="number" value="0" min="0" max="359.9" step="0.1" id="heading" name="heading"/>
<label for="pitch">pitch (en °):</label>
<input type="number" value="0" min="-90" max="90" step="0.1" id="pitch" name="pitch"/>
<label for="roll">roll (en °):</label>
<input type="number" value="0" min="-90" max="90" step="0.1" id="roll" name="roll"/>
</div>
<div>
<table id="table">
<thead>
<tr>
<td>azimut en (°)</td>
<td>elevation en (°)</td>
<td>action</td>
</tr>
</thead>
<tbody>
</tbody>
<tfoot>
<tr>
<td><input type="number" value="0" min="0" max="359.9" step="1" id="azimut"/> </td>
<td><input type="number" value="0" min="-90" max="90" step="1" id="elevation"/> </td>
<td><image src="ajouter.png"/></td>
</tr>
</tfoot>
</table>
</div>
</div>
<script>
const toRad=Math.PI/180;
var scratchHPRQuaternion = new Cesium.Quaternion();
var scratchScale = new Cesium.Cartesian3(1.0, 1.0, 1.0);
var scratchHPRMatrix4 = new Cesium.Matrix4();
headingPitchRollToFixedFrame = function(origin, heading, pitch, roll, ellipsoid, result) {
var hprQuaternion = Cesium.Quaternion.fromHeadingPitchRoll(heading, pitch, roll, scratchHPRQuaternion);
var hprMatrix = Cesium.Matrix4.fromTranslationQuaternionRotationScale(Cesium.Cartesian3.ZERO, hprQuaternion, scratchScale, scratchHPRMatrix4);
result = Cesium.Transforms.northEastDownToFixedFrame(origin, ellipsoid, result);
return Cesium.Matrix4.multiply(result, hprMatrix, result);
sceneModePicker : false,
// globe: false
var customSensor = new CesiumSensors.CustomSensorVolume();
viewer.scene.primitives.add(customSensor);
var listDirections=;
for (var i = 0; i < 3; ++i) {
var clock = Cesium.Math.toRadians(120.0 * i);
var cone = Cesium.Math.toRadians(25.0);
listDirections.push(new Cesium.Spherical(clock, cone));
function getValueNumber(id){
var element=document.getElementById(id);
var value= parseFloat(element.value);
var min =parseFloat(element.min);
var max =parseFloat(element.max);
if(isNaN(value)){
value=0;
if(value<min){
value=min;
if(value>max){
value=max;
return value;
function getValue(id){
return document.getElementById(id).value;
function updateViewer(){
// viewer.scene.primitives.removeAll();
var origineLat=getValueNumber("latOrigine")*toRad;
var origineLong=getValueNumber("longOrigine")*toRad;
var origineHauteur=getValueNumber("hauteurOrigine");
var origine=Cesium.Cartesian3.fromDegrees(origineLong, origineLat, origineHauteur);
var heading=getValueNumber("heading")*toRad;
var pitch=getValueNumber("pitch")*toRad;
var roll=getValueNumber("roll")*toRad;
var modelMatrix=headingPitchRollToFixedFrame(origine,heading,pitch,roll);
customSensor.modelMatrix = modelMatrix;
customSensor.radius=getValueNumber("rayon");
customSensor.intersectionWidth=getValueNumber("epaisseur");
customSensor.lateralSurfaceMaterial= Cesium.Material.fromType('Color', {
color:Cesium.Color.fromCssColorString(getValue('couleurLat'))
customSensor.intersectionColor=Cesium.Color.fromCssColorString(getValue('couleurInter'));
customSensor.directions = listDirections;
function updateTable(){
var tBody=document.querySelector('#table>tbody');
var content='';
listDirections.forEach(function(spherical,index){
var elevation=(spherical.cone/toRad).toFixed(1);
var azimut=(spherical.clock/toRad).toFixed(1);
content+='<tr><td>'+azimut+'</td><td>'+elevation+'</td><td><image src="supprimer.png" data-id="'+index+'"/></td></tr>';
tBody.innerHTML=content;
function addSpherical(){
var clock=getValueNumber("azimut")*toRad;
var cone=getValueNumber("elevation")*toRad;
updateTable();
updateViewer();
function removeSpherical(index){
listDirections.splice(index,1);
updateTable();
updateViewer();
document.getElementById('table').addEventListener('click',function(evt){
var element = evt.target;
if (element.tagName.toLowerCase() === 'img') {
var identification = parseInt(element.getAttribute("data-id"), 10);
if(isNaN(identification)){
addSpherical();
else{
removeSpherical(identification);
var listInput=document.querySelectorAll("div>input");
for(var i=0;i<listInput.length;i++){
listInput[i].addEventListener('input',function(){
updateViewer();
updateTable();
updateViewer();
</script>
</body>
</html>
Thanks it works.
Now I want sensor not to bypass if I place any gltf or shape object in place. How can this be achieved!
https://github.com/kaktus40/cesium-sensors
dist directory can not find…
also,it has no cesium.js file,what should it makes it work? thanks.
在 2016年1月28日星期四 UTC+8下午1:53:32,farouk abdou写道:
how can i show the intersection of the sensor with gltf models or objects and stop the sensor passing through the object,
i used showIntersection = true, but it is not working.
Hi sankin,
The cesium-senor plugin has been deprecated for a while, so we won’t be providing support or fixing bugs. Sorry!
Gabby
