I am trying to add some toggle on off buttons for Orthomsaic, Pointcloud, 3D Model, Tiled Model, Shapes etc.
What is the procedure to add the Buttons
@edallsystems
I found a few community forum threads that can help you get started creating buttons.
If you are looking to add a button to the top-right corner of the toolbar, check out the following thread:
I know it’s possible to add an HTML button to the toolbar’s location seen at the top-right of the Cesium Viewer, which is this:
[image]
However, when a button is added via assigning its < div > class to be the same as the toolbar, it will often sit on top of another button.
Is there a way to add a button to this toolbar such that all of the other, pre-existing buttons will move to the side to allow its placement there, without the button occluding any others?
Ultimately, adding a toggle button to the viewer is more of a general HTML/CSS issue than a CesiumJS issue. The following threads provide great high-level information.
To clarify, I want to overlay a button on top of the viewer like is in the sandcastle example. When I do it like this, it positions the button above the viewer.
toolbarLeftClass: {
display: “block”,
position: “absolute”,
top: “5px”,
left: “5px”
cesiumContainerId: {
position: “relative”,
width: “100%”,
height: “100%”,
margin: “0”,
padding: “0”,
overflow: “hidden”
this.cesiumContainer = element}>
Click me!
Hi!
I have a Cesium panel and I want to put a button at the top of it (see below).
[image]
When the user presses that button, the selected entity must be deleted.
To achieve that goal, I wrote this code:
<h1>My app</h1>
<div ng-show="authenticated">
<div id="cesiumContainer"></div>
<div id="toolbar"></div>
<script>
var viewer = new Cesium.Viewer('cesiumContainer',
timeline: false,
animation: false,
Let me know if you have any other questions or concerns!
-Sam
But, How to define which layer to call?
Like for
Image Layer
Shape Layers
Tileset Layers
GeoJSON Layers etc
Not able to find any information’s on these anywhere.
Can you help out.
Also I need to integrate measurement tool to cesium. How to do that ?
Hi, Is there anyone who can give an answer to my query ?
